#12969 by robertw2
Thu Jan 23, 2003 4:47 pm
#12969 by robertw2
I recently built a new computer. It has Gigabyte motherboard GA-7VKMLS
Rev 3.0 with VIA KM266 AGPset and has 98 SE installed. The BIOS is AMI
BIOS, 2M bit Flash ROM. It has Voodoo3 2000 PCI video card with 16 MB
SDRAM Memory. The machine has worked excellently until I changed VGA
Boot from PCI to AGP in PNP/PCI Configuration section of the BIOS. Now
when computer is turned on screen is blank and no POST is displayed.
Tested monitor and video card with another computer and both work fine.
How do I get my POST screen and change my settings? Any ideas or
suggestions would be appreciated. Thanking you in advance.
