My m.b is a Dragon Platinum Edition SY-P4x400 Dragon Ultra
I'm not to sure where to place the dram clock and multi
any input would be great !
Thanks guys !
CPU-Z version 1.44.1
Processors Map
Number of processors 1
Number of threads 1
Processor 0
-- Core 0
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name Intel Pentium 4
Codename Northwood
Specification Intel(R) Pentium(R) 4 CPU 2.80GHz
Package Socket 478 mPGA (platform ID = 2h)
CPUID F.2.9
Extended CPUID F.2
Brand ID 9
Core Stepping D1
Technology 0.13 um
Core Speed 2792.2 MHz (21.0 x 133.0 MHz)
Rated Bus speed 531.9 MHz
Stock frequency 2800 MHz
Instructions sets MMX, SSE, SSE2
L1 Data cache 8 KBytes, 4-way set associative, 64-byte line size
Trace cache 12 Kuops, 8-way set associative
L2 cache 512 KBytes, 8-way set associative, 64-byte line size
FID/VID Control no
Features
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01001001h
Max CPUID level 00000002h
Max CPUID ext. level 80000004h
Function eax ebx ecx edx
0x00000000 0x00000002 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x00000F29 0x00010809 0x00004400 0xBFEBFBFF
0x00000002 0x665B5101 0x00000000 0x00000000 0x007B7040
0x80000000 0x80000004 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000000 0x00000000
0x80000002 0x20202020 0x20202020 0x20202020 0x6E492020
0x80000003 0x286C6574 0x50202952 0x69746E65 0x52286D75
0x80000004 0x20342029 0x20555043 0x30382E32 0x007A4847
Cache descriptor Level 1 D 8 KB 1 threads
Cache descriptor Level 1 T 12 KB 1 threads
Cache descriptor Level 2 U 512 KB 1 threads
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0x00000017 edx = 0x000A0000 eax = 0x00000000
MSR 0x0000002C edx = 0x00000000 eax = 0x15110015
MSR 0x000001A0 edx = 0x00000000 eax = 0x00000081
Chipset
Northbridge VIA PT800 (VT8754) rev. 03
Southbridge VIA VT8235 rev. 00
Graphic Interface AGP
AGP Revision 3.0
AGP Transfer Rate 8x
AGP SBA supported, enabled
Memory Type DDR
Memory Size 2048 MBytes
Memory Frequency 166.3 MHz (FSB + 33 MHz)
DRAM Interleave 4-way
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 6
Memory SPD
DIMM #1
General
Memory type DDR
Manufacturer (ID) (FFFFFFFFFFFFFFFF)
Size 1024 MBytes
Max bandwidth PC3200 (200 MHz)
Part number
Serial number FFFFFFFF
Manufacturing date Week 255/Year 255
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Nominal Voltage 2.50 Volts
EPP no
XMP no
Timings table
Frequency (MHz) 166 200
CAS# 2.0 2.5
RAS# to CAS# delay 4 4
RAS# Precharge 4 4
TRAS 8 9
DIMM #2
General
Memory type DDR
Size 1024 MBytes
Part number
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
Timings table
CAS# 2.0 2.5
RAS# Precharge 4 4
TRAS 8 9
Dump Module #1
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 80 08 07 0D 0B 02 40 00 04 50 65 00 82 08 00 01
10 0E 04 0C 01 02 20 00 60 70 00 00 50 3C 50 2D 80
20 90 90 50 50 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 87
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Dump Module #2
Monitoring
Mainboard Model P4X400-8235 (0x26F - 0x6E9A14D0)
LPCIO
Vendor Winbond
Model W83697HF
Vendor ID 0x5CA3
Chip ID 0x60
Revision ID 0x16
Config Mode I/O address 0x2E
Dump config mode register space, LDN = 0xB
00 FF FF FF FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 60 16 FF FE 10 00 00 FF 00 80 F0 FF FF 30 00 FF
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor
Winbond W83697HF hardware monitor
Voltage sensor 0 1.47 Volts [0x5C] (CPU VCore)
Voltage sensor 1 3.26 Volts [0xCC] (AUX)
Voltage sensor 2 2.96 Volts [0xB9] (+3.3V)
Voltage sensor 3 4.92 Volts [0xB7] (+5V)
Voltage sensor 4 9.36 Volts [0x9A] (+12V)
Temperature sensor 0 29°C (84°F) [0x1D] (TMPIN0)
Temperature sensor 1 44°C (110°F) [0x57] (TMPIN1)
Fan sensor 1 4327 RPM [0x4E] (FANIN1)
Dump hardware monitor
LPC Register space, base address = 0x0290
bank 0
00 01 FF 01 FF 00 00 00 00 01 01 01 01 3C 3C 0A 0A
20 5B 00 CC B9 B7 9A 5D 1D FF 4E FF 95 85 10 00 10
30 28 30 81 08 00 11 08 00 02 00 04 90 82 00 00 00
40 01 5D 0F FF FF 00 00 AF 2D 02 01 84 58 95 00 A3
50 FF FF 00 FF FF FF 00 80 60 70 FF FF 11 01 FF 05
60 5B 00 CC B9 B7 9A 5D 1D FF 4E FF 95 85 10 00 10
70 28 30 81 08 00 11 08 00 02 00 04 90 82 00 00 00
80 01 FF 01 FF 00 00 00 00 01 01 01 01 3C 3C 0A 0A
A0 5B 00 CC B9 B7 9A 5D 1D FF 4E FF 95 85 10 00 10
B0 28 30 81 08 00 11 08 00 02 00 04 90 82 00 00 00
C0 01 00 00 FF FF 00 00 AF 2D 02 01 84 58 95 00 A3
D0 FF FF 00 FF FF FF 00 80 60 70 FF FF 11 01 FF 05
E0 5B 00 CC B9 B7 9A 5D 1D FF 4E FF 95 85 10 00 10
F0 28 30 81 08 00 11 08 00 02 00 04 90 82 00 00 00
bank 1
50 2B 80 00 73 00 78 00 FF FF FF FF FF FF FF FF FF
bank 2
bank 3
bank 4
50 00 0F 00 00 00 E8 00 00 17 5D 0F 03 11 00 FF FF
PCI Device List
Host Bridge
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x3168
Revision ID 0x03
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x08
Header 0x00
PCI header
Address 0 (memory) 0xE0000000
Subvendor ID 0x1106
Subsystem ID 0x3168
Int. Line 0x00
Int. Pin 0x00
Capabilities
AGP Capability
Offset 80h
Version 3.5
Status enabled
Transfer rate 8x (max 8x)
Queue lenght 2 (max 32)
Power Management Capability
Offset C0h
Version 1.1
Dump
00 06 11 68 31 06 00 30 22 03 00 00 06 00 08 00 00
10 08 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 06 11 68 31
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
40 00 19 88 80 82 44 00 04 11 19 88 80 82 44 00 00
50 A8 FF FF 88 54 85 80 80 EE 00 20 40 60 80 80 80
60 9A AA 2F 20 E6 99 40 15 51 4D 54 D0 41 7C 00 00
70 82 48 00 01 01 01 10 00 01 00 00 00 00 00 00 02
80 02 C0 35 00 0B 0A 00 1F 02 03 00 1F 00 00 00 00
90 00 01 00 00 30 0F 01 00 00 00 01 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 21 42 00 C8
B0 7F 00 10 00 46 00 00 02 46 00 00 00 00 00 00 8E
C0 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 02 33 11 33 11 75 38 42 00
E0 00 00 00 00 00 FF 09 00 9A 77 CC CC 00 00 60 B9
F0 00 00 04 00 00 00 07 00 00 00 00 00 00 04 00 00
PCI to PCI Bridge
bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0xB168
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 80h
Version 1.1
Dump
00 06 11 68 B1 07 01 30 E2 00 00 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 00 90 90 00 00
20 00 E4 00 E4 00 D0 F0 DF 00 00 00 00 00 00 00 00
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 0C 00
40 83 C7 00 44 24 72 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 01 00 02 02 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Ethernet Controller
bus 0 (0x00), device 13 (0x0D), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8139
Revision ID 0x10
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x00
Latency 0x80
Header 0x00
PCI header
Address 0 (port) 0x0000A000
Address 1 (memory) 0xE4120000
Subvendor ID 0x10EC
Subsystem ID 0x8139
Int. Line 0x12
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Dump
00 EC 10 39 81 05 00 90 02 10 00 00 02 00 80 00 00
10 01 A0 00 00 00 00 12 E4 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 EC 10 39 81
30 00 00 00 00 50 00 00 00 00 00 00 00 12 01 20 40
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 01 00 C2 F7 00 01 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Audio device
bus 0 (0x00), device 14 (0x0E), function 0 (0x00)
Common header
Vendor ID 0x13F6
Model ID 0x0111
Revision ID 0x10
PI 0x00
SubClass 0x01
BaseClass 0x04
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 0 (port) 0x0000A400
Subvendor ID 0x10FD
Subsystem ID 0xA407
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset C0h
Version 1.1
Dump
00 F6 13 11 01 05 00 10 02 10 00 01 04 00 20 00 00
10 01 A4 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 FD 10 07 A4
30 00 00 00 00 C0 00 00 00 00 00 00 00 10 01 02 18
C0 01 00 02 06 00 00 00 00 00 00 00 00 00 00 00 00
RAID Controller
bus 0 (0x00), device 15 (0x0F), function 0 (0x00)
Common header
Vendor ID 0x1103
Model ID 0x0004
Revision ID 0x05
PI 0x00
SubClass 0x04
BaseClass 0x01
Cache Line 0x08
Latency 0x40
Header 0x00
PCI header
Address 0 (port) 0x0000A800
Address 1 (port) 0x0000AC00
Address 2 (port) 0x0000B000
Address 3 (port) 0x0000B400
Address 4 (port) 0x0000B800
Subvendor ID 0x1103
Subsystem ID 0x0001
Int. Line 0x11
Int. Pin 0x01
Capabilities
Offset 60h
Version 1.1
Dump
00 03 11 04 00 05 00 30 02 05 00 04 01 08 40 00 00
10 01 A8 00 00 01 AC 00 00 01 B0 00 00 01 B4 00 00
20 01 B8 00 00 00 00 00 00 00 00 00 00 03 11 01 00
30 00 00 00 00 60 00 00 00 00 00 00 00 11 01 08 08
40 A7 4E 81 06 A7 4E 81 06 A7 4E 81 06 62 9C 86 1C
50 05 00 00 00 05 00 00 00 1B 00 00 21 17 00 19 00
60 01 00 22 00 00 00 00 00 00 08 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 5F 00 F6 00 00 00 00 00
USB Controller (UHCI)
bus 0 (0x00), device 16 (0x10), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x80
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x80
PCI header
Address 4 (port) 0x0000BC00
Subvendor ID 0x1106
Subsystem ID 0x3038
Int. Line 0x15
Int. Pin 0x01
Capabilities
Offset 80h
Version 1.1
Dump
00 06 11 38 30 07 00 10 02 80 00 03 0C 08 20 80 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 01 BC 00 00 00 00 00 00 00 00 00 00 06 11 38 30
30 00 00 00 00 80 00 00 00 00 00 00 00 15 01 00 00
40 40 12 03 00 00 00 00 00 00 0B 00 00 00 00 00 00
60 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 01 00 C2 FF 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 03 00 00 00 00 00 00 00 00
bus 0 (0x00), device 16 (0x10), function 1 (0x01)
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x80
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x80
PCI header
Address 4 (port) 0x0000C000
Subvendor ID 0x1106
Subsystem ID 0x3038
Int. Line 0x15
Int. Pin 0x02
Capabilities
Offset 80h
Version 1.1
Dump
20 01 C0 00 00 00 00 00 00 00 00 00 00 06 11 38 30
30 00 00 00 00 80 00 00 00 00 00 00 00 15 02 00 00
bus 0 (0x00), device 16 (0x10), function 2 (0x02)
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x80
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x80
PCI header
Address 4 (port) 0x0000C400
Subvendor ID 0x1106
Subsystem ID 0x3038
Int. Line 0x15
Int. Pin 0x03
Capabilities
Offset 80h
Version 1.1
Dump
20 01 C4 00 00 00 00 00 00 00 00 00 00 06 11 38 30
30 00 00 00 00 80 00 00 00 00 00 00 00 15 03 00 00
USB 2.0 Controller (EHCI)
bus 0 (0x00), device 16 (0x10), function 3 (0x03)
Common header
Vendor ID 0x1106
Model ID 0x3104
Revision ID 0x82
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xE4121000
Subvendor ID 0x1106
Subsystem ID 0x3104
Int. Line 0x15
Int. Pin 0x04
Capabilities
Offset 80h
Version 1.1
Dump
00 06 11 04 31 07 00 10 02 82 20 03 0C 08 20 00 00
10 00 10 12 E4 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 06 11 04 31
30 00 00 00 00 80 00 00 00 00 00 00 00 15 04 00 00
40 00 00 03 00 00 00 00 00 80 10 00 09 00 00 00 00
50 00 5A 04 80 00 00 00 00 04 0B 88 88 53 88 00 00
60 20 20 01 00 00 00 00 00 01 00 00 00 00 00 00 C0
PCI to ISA Bridge
bus 0 (0x00), device 17 (0x11), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x3177
Revision ID 0x00
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1106
Subsystem ID 0x3177
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset C0h
Version 1.1
Dump
00 06 11 77 31 87 00 10 02 00 00 01 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 06 11 77 31
30 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00
40 44 00 F8 00 00 00 00 00 8C 20 00 00 04 00 0A 08
50 C1 0D 09 00 00 00 02 00 43 80 00 00 00 00 00 00
60 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
70 06 11 77 31 00 00 00 00 00 00 00 00 20 00 00 00
80 20 84 59 00 F2 30 00 00 01 04 00 00 02 18 00 00
90 F0 06 0B 88 84 C0 04 00 00 0C 00 00 00 00 00 00
D0 01 05 01 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 45 08 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00
IDE Controller
bus 0 (0x00), device 17 (0x11), function 1 (0x01)
Common header
Vendor ID 0x1106
Model ID 0x0571
Revision ID 0x06
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 4 (port) 0x0000C800
Subvendor ID 0x1106
Subsystem ID 0x0571
Int. Line 0xFF
Int. Pin 0x01
Capabilities
Offset C0h
Version 1.1
Dump
00 06 11 71 05 07 00 90 02 06 8A 01 01 00 20 00 00
20 01 C8 00 00 00 00 00 00 00 00 00 00 06 11 71 05
30 00 00 00 00 C0 00 00 00 00 00 00 00 FF 01 00 00
40 0B F2 09 05 18 1C C0 00 20 20 20 20 FF 00 B6 B6
50 F1 F1 F6 F6 0C 03 00 00 A8 A8 A8 A8 00 00 00 00
60 00 02 00 00 00 00 00 00 00 02 00 00 00 00 00 00
70 02 01 00 00 00 00 00 00 02 01 00 00 00 00 00 00
80 70 8E B7 09 00 00 00 00 60 4C B8 09 00 00 00 00
D0 06 00 71 05 06 11 71 05 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 07 00 00 00 00 00 00 00 00 00
VGA Controller
bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x4E48
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x08
Latency 0xFF
Header 0x80
PCI header
Address 0 (memory) 0xD0000000
Address 1 (port) 0x00009000
Address 2 (memory) 0xE4020000
Subvendor ID 0x1002
Subsystem ID 0x4F72
Int. Line 0x10
Int. Pin 0x01
Capabilities
AGP Capability
Offset 58h
Version 3.0
Status enabled
Queue lenght 1 (max 256)
Offset 50h
Version 1.1
Dump
00 02 10 48 4E 87 00 B0 02 00 00 00 03 08 FF 80 00
10 08 00 00 D0 01 90 00 00 00 00 02 E4 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 72 4F
30 00 00 00 00 58 00 00 00 00 00 00 00 10 01 08 00
40 00 00 00 00 00 00 00 00 00 00 00 00 02 10 72 4F
50 01 00 02 06 00 00 00 00 02 50 30 00 1B 02 00 FF
60 02 03 00 1F 00 00 00 00 00 00 00 00 00 00 00 00
80 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Display Controller
bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x1002
Model ID 0x4E68
Revision ID 0x00
PI 0x00
SubClass 0x80
BaseClass 0x03
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xD8000000
Address 1 (memory) 0xE40F0000
Subvendor ID 0x1002
Subsystem ID 0x4F73
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset 50h
Version 1.1
Dump
00 02 10 68 4E 87 00 B0 02 00 00 80 03 08 20 00 00
10 08 00 00 D8 00 00 0F E4 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 73 4F
30 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 08 00
60 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DMI
DMI BIOS
vendor Phoenix Technologies, LTD
version 6.00 PG
date 10/04/2002
DMI System Information
manufacturer VIA Technologies, Inc.
product P4X400-8235
version unknown
serial unknown
UUID FFFFFFFF-FFFFFFFF-FFFFFFFF-FFFFFFFF
DMI Baseboard
vendor unknown
model P4X400-8235
revision unknown
serial unknown
DMI System Enclosure
manufacturer unknown
chassis type Desktop
chassis serial unknown
DMI Processor
manufacturer Intel
model Intel Pentium(R) 4
clock speed 2800.0MHz
FSB speed 133.0MHz
multiplier 21.0x
DMI Memory Controller
correction unknown
Max module size 32MBytes
DMI Memory Module
designation A0
size 1024 MBytes (double bank)
DMI Memory Module
designation A1
DMI Memory Module
designation A2
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation SECONDARY IDE (internal)
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation COM2 (internal)
connector DB-9 male
DMI Port Connector
designation LPT1 (internal)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
port type Mouse Port
connector PS/2
connector PS/2
DMI Port Connector
designation USB (external)
port type USB
DMI Port Connector
designation AUDIO (external)
port type Audio Port
DMI Extension Slot
designation PCI0
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI3
type PCI
width 32 bits
populated no
DMI Extension Slot
designation AGP
type AGP
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 768MBytes
max# of devices 3
DMI Memory Device
designation A0
format DIMM
type unknown
size 1024 MBytes
DMI Memory Device
designation A1
format DIMM
type unknown
size 1024 MBytes
DMI Memory Device
designation A2
format DIMM
type unknown
Software
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX Version 9.0c
Resources
Memory I/O Space, BA=0x00000000E0000000
Port I/O Space, BA=0xA000
Memory I/O Space, BA=0x00000000E4120000
Port I/O Space, BA=0xA400
Port I/O Space, BA=0xA800
Port I/O Space, BA=0xAC00
Port I/O Space, BA=0xB000
Port I/O Space, BA=0xB400
Port I/O Space, BA=0xB800
Port I/O Space, BA=0xBC00
Port I/O Space, BA=0xC000
Port I/O Space, BA=0xC400
Memory I/O Space, BA=0x00000000E4121000
Port I/O Space, BA=0xC800
Memory I/O Space, BA=0x00000000D0000000
Port I/O Space, BA=0x9000
Memory I/O Space, BA=0x00000000E4020000
Memory I/O Space, BA=0x00000000D8000000
Memory I/O Space, BA=0x00000000E40F0000
Port I/O Space, BA=0x408, size=0x4
Memory I/O Space, BA=0x00000000FEE00000, size=0x1000
Port I/O Space, BA=0x500
Port I/O Space, BA=0x290
Port I/O Space, BA=0x2E
