First off, many thanks fr your replies.
Denniss wrote:Do they not work or do they not even install ?
Have you fully updated your Win98SE using Windows Update ?
Latest DirectX9 installed ?
They install but they don't seem to work. Win 98SE has all the updates. Direct X won't install because the sound driver won't install/fails to recognise.
edwin wrote:Is it still the original Time-installed soundcard or was it replaced afterwards?
I installed the 'Intel Chipset Series Mainboard Utility CD' that came with the computer after reinstalling 98 SE and it didn't seem to do anything. It states there are audio drivers on the CD but they don't seem to do anything.
Thanks in advance.
