Ad blocker detected: Our website is made possible by displaying online advertisements to our visitors. Please consider supporting us by disabling your ad blocker on our website.
2gator
Posts: 1 Joined: Sat Jan 01, 2005 2:15 am
Sat Jan 01, 2005 2:20 am
I work on computers and I come across a new one to me.
I install a factory new bios on a ABITKT7A and i have the same problem and I have tryed everything.
If you reset the bios time clock and reboot you can then go in a set up everything but if you reboot it just hangs on the memory check.
If you remove the battery you can then reboot till you need to shut down again then it hangs again.
Other then that the puter runs fine ....any ideas?
walt
ajzchips
El cheapo dude
Posts: 3048 Joined: Sat Mar 23, 2002 12:41 pm
Sat Jan 01, 2005 10:26 pm
What does your
set up everything
include? Perhaps aggressive RAM timings?
