i can't find an update for my microstar m2-6323 that supports a 80Gb HD.
On msi web site i can't find any working update...
please help me!
help ms-6323
these are the info.
I just update the bios to 1.1 rev (from msi web), but i didn't solve yet my problem.
waiting for help...and many thanks
BIOS Date: 01/19/01
BIOS ID: 01/19/2001-694X-686A-6A6LJM4CC
OEM Sign-On: W6323MS V1.1 011901 10:58:39
Chipset: VIA 82C691 rev 196
Superio: VIA 686 rev 34 found at port 7h
OS: WinME
CPU: PENTIUM III 700 Mhz MAX: 800 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 320 MB
Memory Maximum: Unknown
Memory Slot 01: 64 MB
Memory Slot 02: 256 MB
eSupport.com, Inc.
1-800-800-BIOS (2467)
www.esupport.com
BIOS Date: 01/19/01
OS: WinME
BIOS ROM Size: 256K
eSupport.com, Inc.
www.esupport.com
award series 6 from 2001 that has no 80GB support? That would be a firsttimer. What does happen when you connect the 80GB harddisk (brand/model)?
everything seems to be working properly. I've found that the problem was the OntrackDDO software (supplied by Maxtor to overcome HD size 32Gb problems); by removing this, disk is seen as 80G by WinME too.
Anyway a message still appears at boot, something like "warning, primary IDE has not 80 pin cable"... I'm sure that the cable is 80pin (i've also tried with a new one), and i don't know why. What's the problem?
thanks and BR
V.
P.S. primary HD is Fujitsu 20G (don't remember model) as master and secondary is Maxtor 4K080 80Gb as slave. Bios rev is 1.1
thanks and BR
V.
