I updated my Epox 4G4A bios successully, then rebooted and all I see now is:
Award BootBlock Bios 1.0
Copyright (c) 2000
BIOS ROM checksum error
Detecting floppy drive A media..
Automatic Load AWDFLASH.EXE
!!ERROR -- LOAD AWDFLASH.EXE Failed!
Replace the disk and press enter.
Problem is that it automatically tries to load a awdflash.exe not autoexec.bat if there is even one on the disk.. And if I copy only the .bin file and awdflash.exe on to disk, then it says that: The program file's BIOS-Lock string does not match with your system!
Any ideas?
Award BootBlock issue
or what does that error mean: "The program file's BIOS-Lock string does not match with your system!" ???
now I figured out that I updated my 4G4A´'s bios to 4G4A+ bios.. actually it wasn't not only my fault: on the epox's my mobo site is newest bios to download the 4G4A+ 's bios.. but in that "newest bios for my mobo (version 2B04)" readme is not listed my mobo model - 4G4A ..
and I used Alt+F2 method to update my bios, so it didn't even ask me any parameters or smt, just automatically updated bios from disk..
now I'm in pretty big trouble..
The BIOS ID string in the BIOS on floppy does not match the BIOS ID string already on the board, which makes sense if you flashed the wrong BIOS into the board. Does this mean you can now load AWDFLASH ?xerom wrote:or what does that error mean: "The program file's BIOS-Lock string does not match with your system!" ???
On their website http://www.epox.nl/english/support/bios/pentium4.htm the BIOS http://www.epox.nl/BIOS/4G4A2B04.zip is listed for 4G4A / 4G4A+ / 4G4AN / 4G4AI. Did you use this ? If you used it, try emailing to complain.now I figured out that I updated my 4G4A´'s bios to 4G4A+ bios.. actually it wasn't not only my fault: on the epox's my mobo site is newest bios to download the 4G4A+ 's bios.. but in that "newest bios for my mobo (version 2B04)" readme is not listed my mobo model - 4G4A ..
Do you have your original BIOS saved ?
Yes. Award BootBlock automatically loads the AWDFLASH.EXE from floppy and this loads automatically the first .bin from floppy, and then gives a error about bios id string.NickS wrote:Does this mean you can now load AWDFLASH ?
Yes, I used this 4G4A2B04.zip. It is said on their Euro HQ that it is for 4G4A, but if you download this same bios from their USA HQ, then you will get readme file in that packed .exe file. And in that readme there is not listed my mobo's (4G4A) model anymoreOn their website http://www.epox.nl/english/support/bios/pentium4.htm the BIOS http://www.epox.nl/BIOS/4G4A2B04.zip is listed for 4G4A / 4G4A+ / 4G4AN / 4G4AI. Did you use this ? If you used it, try emailing to complain.
And I don't have the backup, because I used the Alt+F2 method to update my bios, it didn't even ask me any parameters or smt, just updated a bios from floppy.Quote from the readme.txt included in 4G4A2B04.exe downloaded from Epox USA HQ: wrote: Bios filename: 4G4A2B04.BIN
Bios date: 11/4/2000
Bios size: 512 KB (For 4Mb BIOS EEPROM)
Bios checksum: 4600
Model support: EP-4G4A+, EP-4G4AR
Looks as though your options are:
1. Complain and ask for a replacement
2. Pay 17.5 euros for a replacement
3. "Hot-flash" (hot-swap flash) reprogramming in another board - see http://www.pppr.sk/rainbow/hardware/hotflash.html - with an older BIOS from the USA site.
4. Get someone with an EEPROM programmer to program the older BIOS into your chip.
The puzzling thing is that the AWDFLASH complains when the BIOS strings are identical for both the 2A31.bin which says it supports the 4G4A and the 2B04.bin which does not, i.e.:
i845G-W83627-6A69VPAKC-00.
Awdflash complains about BIOS-Lock string. That's some stupid crap found in some BIOSes for unknown reason.
@rainbow - any solution besides what I suggested ? Do all versions of Awdflash look for the lock string ?Rainbow wrote:Awdflash complains about BIOS-Lock string. That's some stupid crap found in some BIOSes for unknown reason.
Older versions do not support BIOS lock. v7.79 has BIOS lock, v7.63 does not.
So you think that I might be able to update my bios with awardflash v7.63? Where can I download different versions of awdflash?Rainbow wrote:Older versions do not support BIOS lock. v7.79 has BIOS lock, v7.63 does not.
Doesn't work. It gives me "Unknown Flash Type!" error..Rainbow wrote:Try it http://cable.pchome.net/drv/others/bios/awdflash.zip
v7.63 does not support SST 49LF004A
v7.76 does but has BIOS lock...
but there are still few versions of awdflash between v7.63 and v7.76.. v7.64 and v7.72 for example.. what about these versions? do they have bios lock or do they support SST 49LF004A ?Rainbow wrote:v7.63 does not support SST 49LF004A![]()
