I am new with the BIOS setting change for AMI.
I am trying to use afulnx currently and need to install the AFULNX driver as prompted but keep on having below error:
- Program initializing ..
- Make AFULNX driver .... fail
Please advice.
Thanks.
SY
AFULNX USER'S GUIDE
INTRODUCTION
The files that come within AFULNX.TGZ are:
File Name Description
readme.txt This file.
afulnx_26_32 afulnx 2.6 kernel 32bit executable.
afulnx_26_64 afulnx 2.6 kernel 64bit executable.
To run AFULNX, the AMI Flash driver must be built on your running Linux.
Read 'AFULNX' section for details of running afulnx.
Read 'DRIVER' section for details of building the driver.
AFULNX
Afulnx has two versions. One is 32-bit version named 'afulnx_26_32'.
The other is 'afulnx_26_64' which is for 64-bit platform.
To determine which one to use, type 'uname -m'. If it says 'x86_64', then
64-bit version should be used; otherwise, use the 32-bit version.
Please read 'Q3' in the 'TROUBLESHOOTING section' below before running
afulnx.
Type './afulnx_26_32' or './afulnx_26_64'
to see a list of available commands and flash your BIOS anyway your want.
DRIVER
1. Log in Linux as root.
2. The compiler suite(gcc) must be installed. If these packages are not
installed, the driver CANNOT be built.
3. For most distributions, AFULNX will generate AMI Flash Driver file
automatically without notification. Certainly, the driver file may NOT be
generted in some specific case and the loading driver failure message
will be displayed. If you get this error, first, you can read 'Q1' and 'Q2'
in 'TROUBLESHOOTING section' to shut out the kernel issues, and second,
you can see Point.4 below to create driver file by yourself and launch
AFULNX again.
4. Kernel sources must be installed, *CONFIGURED*, and then compiled.
Following are steps to do this:
4.1 Find Running Kernel's Configuration File:
To configure the sources, simply change to the kernel source directory
(typically /lib/modules/$(uname -r)/build). If it doesn't exist,
you need to install kernel source. Typically, the reference configuration
for the kernel can be found in the /boot directory with filename
'.config', 'kernel.config', or 'vmlinux-2.4.18-3.config'. Type 'uname -a'
and use the configuration filename that best matches the output from
'uname -a'.
On some distributions Red Hat for instance, there is a config
directory under /lib/modules/$(uname -r)/build.
Copy this configuration file into the root of the linux kernel source
tree(usually it is /lib/modules/$(uname -r)/build).
This file must be renamed to ".config"(dot config).
4.2 Make Your AMI Flash Driver (amifldrv_mod.o):
For most distribution, the command to build the driver is:
afulnx_26_32 /MAKEDRV
or
afulnx_26_64 /MAKEDRV
If your linux's kernel source tree is under /lib/modules/$(uname -r)/build
instead of the default path '/lib/modules/$(uname -r)/build',
add a KERNEL flag:
afulnx_26_32 /MAKEDRV KERNEL=/lib/modules/$(uname -r)/build
or
afulnx_26_64 /MAKEDRV KERNEL=/lib/modules/$(uname -r)/build
If KERNEL is omitted, the default is /lib/modules/$(uname -r)/build.
This should work for MOST distributions.
4.3 Make Your AMI Flash Driver from dirver source files (amifldrv_mod.o):
Using command /GENDRV, it will generate driver source files to specific directory.
afulnx_26_32 /GENDRV [Option 1] [Option 2]
or
afulnx_26_64 /GENDRV [Option 1] [Option 2]
[Option 1]: Specific kernel source 'KERNEL=XXXX' same as the /MAKEDRV
[Option 2]: Specific output directory 'OUTPUT=XXXX'
Generate files as below:
amiwrap.c Driver source code.
amiwrap.h Driver header.
amifldrv.o_shipped Object file for driver.
Makefile Makefile
make
add a KERNEL flag:
make KERNEL=/lib/modules/$(uname -r)/build
4.4 Check Your Build:
Check the version of running Linux kernel with 'uname -r'.
Check the version of amifldrv_mod.o with 'modinfo amifdrv_mod.o'.
If they mismatch, you will need to select the correct configuration
file(.config), rebuild your kernel, and then rebuild your driver as
described in (4.1), (4.2), (4.3) and (4.4).
The amifdrv_mod.o must be in same directory with afulnx_26_32
(afulnx_26_64).If they match, continue on to the 'AFULNX' section
to run afulnx.
TROUBLESHOOTING
Q1: I get following error message when loading driver:
"insmod: error inserting 'amifldrv_mod.o': -1 Invalid module format".
A1: Most likely this is cause by wrong configuration file and your kernel
refuses to accept your driver because version strings(more precisely,
version magic) do not match.
To check the version of running Linux kernel, type "uname -r".
To check the version of amifldrv_mod.o, type "modinfo amifdrv_mod.o"
described in section 3.
Q2: When I run ./afulnx_26_32(./afulnx_26_64), it says "Unable to load driver".
A2: Some Linux distributions do not display driver debug messages on screen
by default. Type "dmesg" to see those debug messages. This is very likely
the same problem as Q1.
Q3: When I run ./afulnx_26_32(./afulnx_26_64), it simply freezes.
A3: This is caused by a Linux feature called "NMI Watchdog" which is used to
debug Linux kernel. This feature must be disabled to run AFULNX.
Please do "cat /proc/interrupts" twice and check if NMI is counting.
If it is, then boot Linux with a kernel parameter "nmi_watchdog=N"
where N is either 0, 1 or 2. Find out which configuration can halt NMI
from counting by "cat /proc/interrupts" This is the configuration we
should use to run AFULNX.
Q4: Do AMI Utilities support XEN?
A4: Yes. AFULNX v2.35 or later has supported XEN, but BIOS must to add the "RuntimeMemoryHole" Module.
For any further information please see release note for detail.
REFERENCES
Linux Loadable Kernel Module HOWTO
http://www.linux.org/docs/ldp/howto/Mod ... index.html
