ACPI PROBLEM!
APM/ACPI BIOS questions
alexdelarge
I have an asus CUV4x motherboard, and a Pinnacle Studio Deluxe that doesn't work with ACPI. I disabilitate ACPI in win2000 and tryed to do the same thing in BIOS... but there's nothing about ACPI disabilitation in BIOS!! I uploaded from official asus site the latest version, but nothing, i can't see the Enable/disable ACPI functions... i'm disperated! Can anyone help me? thanks...
alex
Rainbow
The UniFlasher
You can't disable ACPI on most newer boards.
ajzchips
El cheapo dude
...but Windows 2000 can be told not to install in ACPI mode.
soupy
Absentee administrator
What exactly is the problem?
alexdelarge
I can't disable ACPI in BIOS because there isn't any selector
stonent
BIOS Rookie
soupy wrote:What exactly is the problem?
Many high end audio cards for professional use do not work correctly if they have to share an IRQ with another device via ACPI. They will produce audio anomalies, pops, clicks, static, background noise.
Stonent
http://home.comcast.net/~stonent Stonent's Dell laptop site
soupy
Seems strange that it would matter, since, after all, only one interrupt can be serviced at a time.
Anyhow, like AJZ said, force a Standard PC install under Win2000.
Pinnacle again. First not compatible with PnP (long ago), now the same thing with ACPI, will they ever learn..
