Suspend and hibernation don't work on my Windows XP system.
The computer does not do anything after I enter suspend state (like it hangs; keyboard lights don't function); I have to shut-down and reboot to reuse it. Hibernation is 'ignored' when I reboot the system after hibernation.
I've tried all the BIOS settings, but nothing works. Any suggestions?
Enhanced Disk Drive
Specification : BIOS doesn't support this feature
DMI Version : BIOS supports minimum version 2.1. Latest is
version 2.3
ACPI Version : BIOS currently supports latest version 1.0
BIOS Chip in Socket : BIOS currently supports this feature
Supports LS-120 Booting : BIOS doesn't support this feature
Supports ZIP Booting : BIOS doesn't support this feature
Supports Network Booting : The testing of this feature is not supported by
the current DMI version
BIOS ID : 08/03/2000-i440BX-W977-2A69KM4AC-00
BIOS Date : 08/03/00
BIOS OEM Signon : W6119MJ V2.9 120100
BIOS ROM Size : 256K
Chipset : Intel 440BX/ZX rev 3
Super I/O Chip : Winbond 83977TF found at port 3F0h
