How to find BIOS mfg?
I have asked in a couple places with no luck. I tried looking all over for the manufacturer of the Bios but no luck. All I can come up with is 68CPK Family Rev. F.21. I have a HP Probook, I hit esc to enter BIOS if any of that helps. Thank You.
F21 is the last release for that notebook:
http://bizsupport1.austin.hp.com/bizsup ... 9-1&mode=3
It doesn't matter what the bios manufacturer is, what matters is, there's no free bios upgrade out there other than from HP. You can try a commercial upgrade from esupport, maybe they can help you.
http://biosagentplus.com/
