I'm trying to flash BIOS on my Toshiba Satellite C55-B5202 using afudos.exe. I downloaded BIOS from Toshiba website and extracted the following two files.
BIOS.ROM
EC.ROM
I was able to flash BIOS.ROM using afudos.exe BIOS.ROM /p /b /n /k. But I can't find a way to flash EC.ROM. Do I need to merge them together before flashing them, or? Thanks for your help.
How do I flash Toshiba Satellite C55-B5202 EC ROM?
The EC is for theEC chip also known as KBC chip which controls keyboard, some voltages on other chips and several other functions. I don't know what utility to use for programming it, if you flashed the main bios and the laptop functions I think there is no need to downgrade the KBC chip. In fact from what I read elsewhere you risk breaking the laptop altogether.
