I would like your help if possible.
I have 2 NUC11TNBV5 that do not boot after failed bios update.
The symptoms after the failed update are as follows:
When I plug the power source, after 5 secs maximum the NUC turns on on it's own and after 5 secs again the power button is starting flashing white constantly.
I used CH341 black to dump the bios and after downloading the correct bios from ASUS I used NeoProgrammer to flash it.
Unfortunately, the same issue still occurs. Am I boned and some firmware like PD chip, is also bricked and prevents the post from completing?
