Mobo in question: EpoX EP-8K7A mobo flashed up to Award v6.00PG with an ID string of 03/15/2001-761-686B-6A6S6PAAC-00 (full info at bottom).
Drive in question: IBM Deskstar 76.8GB DTLA-307075 ATA/IDE 7200RPM
I tried the drive on all four IDE connectors, setting master/slave as appropriate without any success in getting it recognized. The system would eventually boot in safe mode without recognizing the drive. I tried IBM's DiskMaster(?) program, but it only locked up during the reboot phase after it supposedly set up some auto-run thingy to allow proper recognition and full formatting. So much for that.
I planned to RMA it, but set it aside, forgot it, and now it's a two year old never-used drive. *shrug*
At any rate, I would like to know if the BIOS I have is capable of supporting drives of this size, and/or if it has one of those 32/64 gig bugs which is causing the problem. Note that I tried the drive with the 32GB clip jumper settings which didn't help either (presumably that should negate those bugs if that were the culprit).
Currently, I have 3 other drives on the connectors, and had one of those on the now empty connector in the past, so the connectors are all functional.
A couple of trailers:
a) The drive's motor seems *very* loud relative to my other drives, though it appears to be spinning up on power-up and otherwise functioning physically. Not sure if this is typical of this model or if it indicates something bad, or if this is just typical of IBM's 7200 drives.
b) Is this BIOS capable of handling a 120GB drive such as a Maxtor DiamondMax Plus 9 drive?
TIA for info. I am anxious to get a fat drive ASAP, but have been burned once and learned my lesson to ask first and bide my time.
complete bios report:
BIOS Date: 03/15/01
BIOS ID: 03/15/2001-761-686B-6A6S6PAAC-00
BIOS Eval: 03/20/2001 For AMD761 Chipset
Chipset: AMD 700E rev 19
Superio: VIA 686 rev 64 found at port 7h
(Is there a newer BIOS for me?)
