I try to make un bios upgrade end after restart, nothing functions: dsisplay, floppy.. I have a moterboard Intel end bios award
excuze my linguage
My motherboard is complitly dead1
What make and model is your motherboard ? If you don't know, what writing can you find on the motherboard ?
What BIOS file did you use ?
Where did you find that BIOS ?
Does the FDD try to read a diskette ?
