Hi there,
I have a 41,1 GB IBM Deskstar 40GV (Model: DTLA - 305040).
My bios specs are:
BIOS ID: 01/28/1999-ALADDIN5-2A5KKG09C-00
I have a Gigabyte Motherboard (GA-5AX Rev.4) which had the BIOS Version 1.4b. I updated this version to BIOS Version F1 but the bios still identifies the capacity of the hard disk as 32 GB instead of the full hard disk capacity.
Then i wrote a mail to support of gigabyte and they told me to update to BIOS version F4. i did so but the capacity already is 32 GB.
Can anyone help me?
Thank you
41,1GB: 01/28/1999-ALADDIN5-2A5KKG09C-00
That BIOS supports big drives - see http://www.wimsbios.com/phpBB2/viewtopi ... ight=ga5ax
Are you sure that you managed to flash the F4 BIOS OK ?
If so, did you remove the Cylinder Limit (32GB clip) jumper from the drive ?
