Hi I built a system using this board using a k6-2 and currently its running happy with an 8.2gb. I would like to upgrade it with an 80gb hard drive but obviously its a no-go
Another thing is that this board supports voltages 1.8v on up and should be an excellent client for a k6-2 or k6-2+ bios mod. Currently it runs quickly with my k6-2 but does not recognize the speed, although the cache is enabled but 3dnow is not. Also the current bios will not post with the processor set above 366mhz (if it does it freezes with CPU speed = 0mhz) Set to 366mhz it thinks the k6-2 is 16mhz AMD MMX cpu but runs fairly quick. (speed displayed goes up as processor speed decreases
If there is a beta bios or a later bios for this board I'm all ears, its a shame that a board that meets all the needs of a k6-2 doesn't have a bios to use one.
Any help is appreciated, this is for a friend his email is
[email protected] my email as always is [email protected]
Cheers
Ryan
