Hallo,
I have a new 80 GB HDD and my Bios does not support the HDD.
I need an update for my Bios which support 80 GB HDDs.
I mean I have an 1 MB Bios
Any Data:
MY mainboard: NMC/Enmic 5vMX
Program: Unicore BIOS Wizard Version 3.2
Program: eSupport.com BIOS Detect v1.1 June 4, 2003
BIOS Date: 07/06/99
BIOS ID: 07/06/1999-MVP3-596-W877-2A5LENMDC-00
OEM Sign-On: NMC 07/06/1999 For Apollo MVP3 AGP/PCIset
Chipset: VIA 82C597 rev 4
Superio: Winbond 877TF (use 87h) rev 0 found at port 3F0h
OS: Microsoft Windows ME Version: 4.90.3000
BIOS ROM In Socket: Unknown
BIOS ROM Size: Unknown
CPU Type: Unknown
CPU Speed: Unknown
CPU Max: Unknown
Memory Installed: Unknown
Memory Maximum: Unknown
I thanks you for Help
Your
DragonHunter4000
80GB: 07/06/1999-MVP3-596-W877-2A5LENMDC-00
DragonHunter4000
soupy
- Absentee administrator
http://www.enmic.de/default.php?pg=products&pid=102
Looks like the new BIOS is 2Mbit. If you have a 1Mbit chip, you'll need to: a) order a new pre-flashed chip, or b) patch and reflash your current BIOS.
DragonHunter4000
Hallo
Where can I find a patch for my Bios. I will install the 2 Mbit Version an then the flash program say it ist the wrong size for my Bios. I need a patch which permits to install an 2Mbit Bios or a Patch which support 80 GB HDDs in the 1Mbit Version.
OR Where can I buy a pre-flashed Bios?
Your
DragonHunter4000
Your
DragonHunter4000
I have some problems with upload (uploading files & sending big e-mails), so wait until someone else patches it.
(ENMIC 5VMX 1Mbit).zip
http://wims.rainbow-software.org/edwin/
Please let us know how it works out and what brand/model harddisk you used.
