I cannot find a manual for the board of a friend of mine. The board is from a Compaq Deskpro EP/SB with a 350 MHz Pentium II. A Compaq tool identifies it as a 8915CCJ82038. Google has zero hits for that string and the Compaq/HP homepage is just a mess. Anybody know of a place where to get a manual? TIA.
Best
Rolf
Manual for Compaq board
From what I can turn up from the posted info. the board is codenamed GARRY.
Will see about digging up a manual/tech. doc.
http://www.s87841630.onlinehome.us/mode ... garry.htmlToby B. wrote:Proprietory as heck but we at least have some info and now a pic of this board for referrence:evasive wrote:Found a shred of paper with some notes:
Deskpro EP C266/2.1 NTL id 686T1
332857-001 008312-512 GARRY 13/7
s/n 8829BYN20xxx
2xSER/PAR/MS/KB/2xUSB
3ISA/3PCI/AGP Slot1
2xDIMM
ATX PWR
1xFDD
IDE
IDE
front panel
+o-+-xx+-
pwr led hdd led pwr sw scsi led
gonna see if I can dig some more info up....
Compaq-Fu Master
Compaq-Fu Master
Looks exactly like the dead board I have here (a topic about it is somewhere at this forum)...
yeah I remember that thread. At this time we have not managed to identify the board past a codename.
edit
heres Rainbow's thread:
http://www.wimsbios.com/phpBB2/viewtopi ... mpaq#21681
edit
Compaq-Fu Master
Oh, it's not exactly the same board - different number of slots...
Rainbow wrote:Oh, it's not exactly the same board - different number of slots...
Compaq-Fu Master
edwin wrote:"evasive"? on wimsbios.com? getting confused here![]()
Compaq-Fu Master
ChRoNoS_KenS
try here for your deskpro http://h18000.www1.hp.com/support/files/deskpro/us/
you do NOT have the exact same board then as this one has NO three-pin connector there. It might be a fan connector but I wouldn't count on it, the original case design uses a PASSIVE cooling block on the CPU and a HUGE fan in the case blowing at the CPU...jkwim wrote:I have the exact board shown in the above picture. There is a white connector behind and to the left of the serial ports with 3 pins sticking up. Is that a fan power connector ?
