how to build 128KB bios image out of 256 kbyte bios image ?
maman
- Master Flasher
I've successfully release "unneeded" stuff from my mainboard bios without loss of any important functionality. The "unneeded" stuff is the EPA logo, and a custom EPA procedure (procedure to display the EPA logo). The size of this new image is a bit less than 128Kbyte (compressed), but the original size of the bios image is 256Kbyte, hence cbrom or modbin will always emit 256Kbyte image out of this modified image. I intend to make it just 128 Kbyte image, and I have 128Kbyte flash chip to experiment with it. Is it possible at all to make a new 128 kbyte image? if it's possible then how to accomplish it?
I've seen something like that in bp http://www.rom.by but never tried it.
This feature was still under development in the last available version of BP.
maman
- Master Flasher
aha.., I see
. I've been "studying" BP for several weeks. I haven't got anytime testing it, but it's a very nice software. Thx, for the info. BP didn't mention about that feature in its readme file.
Code: Select all
bp-4_51 /hCode: Select all
/u - "ultrapack": packs 2Mbit/4Mbit-BIOS to 1Mbit (N/A - in development)
Why? The uncompress routine is also replaceable, isn't it?maman wrote:so it must still a variant of the LZH
maman
- Master Flasher
yup right, I'm just fool enough right now, not being able to implement a better compression routine in assembly language other than variant of the "moving window" such as LZH
to meet the small space requirement in the BIOS.
apple_rom
It`s possible. I even once upon a time successfully this do. But this anymore was required, therefore so and not realize this possibility in its program (though on 80% has written).Is it possible at all to make a new 128 kbyte image?
1. remove ALL not-used files. (as a rule, stays only "original.tmp" and "awardext.rom").if it's possible then how to accomplish it
2. place original.tmp in begin of 128k-bios.
3. awardext.rom place in the end of him and some not-used places (u can divide by some parts).
4. rewrite unpacking-procedure in boorblock - after unpacking "original.tmp" so to first was going to from pieces your awardext.rom on original.tmp-place, and after that uncompress him...
Some comments - you not will have no DMI/ESCD, and must to remove CRC-checking...
maman
- Master Flasher
I have done thisapple_rom wrote: 1. remove ALL not-used files. (as a rule, stays only "original.tmp" and "awardext.rom").
