Code: Select all
error!
0012 No more matching filesCode: Select all
BP.exe bios.binHere is the M08 BIOS for this motherboard:
http://www.magic-pro.com/download/BIOS/7DR4PM08.zip
Can anyone help?
Code: Select all
error!
BP.exe bios.binIn the BIOS setup page, I can only set "CPU Host Clock" from 100 to 132Mhz.Denniss wrote:Did you set up your board to run with 166MHz FSB (FSB333) ?
What additional files?ajzchips wrote:BP requires some additional files in order to run.
Anyway, that BIOS is quite recent... enough to recognize Semprons, I believe.
cbrom.exePhil_123 wrote:What additional files?
I am using BP 4.0.RC_F.sulbert wrote:cbrom.exePhil_123 wrote:What additional files?
lha.exe
reall.cod (although not used, the microcodes for Intel processors should be there AFAIK)
What version of BP are you using? 4.23?
