Recently, i entered setup after restarting my computer and began to change my computers processor speed, which i eventually increased to 5x 100mhz, and since then i can't get back to windows 98, and even setup. I have tried taking the battery out for awhile, and removing all power cables, but nothing. I have been told i have to either reset my bios or alter my cmos. How can i do that if i can't enter setup. All i get after starting my computer up is a black screen. My bios is the following.
52-0315-001437-00101111-071595-000000
AMI BIOS - Release 03/15/1999S
Motherboard
M598-H Ver 5.0
S5 Dec 1998 Hsing Tech is the company
If anyone knows how i can fix my computers current problem without having to enter setup, please let me know. Again i can't get to setup and windows 98 after starting my computer up. So as far as i know i have to do this another way, without having to enter setup and os.
My computer will not boot. I can't get into setup.
http://mldisplay.com.br/m598.pdf
use JP3 to clear the cmos settings.
maybe you shouldn't play around with bios settings you don't know or try to overclock a K6-2 from 400 to 500MHz ;)
