Is it possible to modify/inject some code into the bios of, say, an asus p2-99 (440zx-based, award bios) to make it send out either to vga or a serial port the registers that it programs on the northbridge, as it's doing it? Or can this info be obtained through reverse engineering? And as far as bricking the motherboard goes, if anyone may be concerned with that, I have a BIOS savior.
Or, could I somehow do this through QEMU or VMWare, since both of these emulate 440bx chipsets, use the p2-99's BIOS along with some userspace tool?
edit: Probably should have mentioned, I'm only interested in up until and including sdram initialization
Monitoring BIOS register programming
maman
- Master Flasher
I think these will help you:
Award BIOS Code Injection
Pinczakko's Guide to Award BIOS Patching
A preliminary basics for the reverse engineering is at:
Pinczakko's Guide to Award BIOS Reverse Engineering
goodluck
goodluck
