my ECS 741GX-M doesnt recognize Geode CPUs.
The Bios-Updates of ECS doesnt support it, because the hardware supports only until 1.25V instead of 1.24V by AMD.
Versions of japanese Bios (based on Award modular Bios 6.00PG ??)
obviously do.
Is there any Bios-Update wich supports Geode CPU on my board ?
Thank you for your help !
BIOS-ID-String: 10/13/2005-SIS-741-6A7I8E19C-00
Geode Support for ECS 741GX-M
the voltage id is not set by the bios in the first place but by the cpu itself. since the voltage regulator supports the cpu's voltage id (obviously, how did you measure the 0.01V difference?) and the geode NX cpu is just a standard athlon cpu core with reduced core frequency and thus reduced voltage there's no real need for a bios update.
i dont measure the 0.01V. I read about the 1.24V of the Geode and the possible 1.25V of the Mainboard.
The Mainboard shows 1.58V as core voltage and the cpu becomes "warm" very fast, so i did not use it now to prevent damages.
The Mainboard recognizes it as a XP 2200+.
the geode VID pins are setup for mobile use. if the mainboard misses the ability to detect that and reduce the voltage accordingly those VID pins will be interpreted as desktop VID pin configuration and result in a higher voltage. it seems that your mainboard doesn't care about mobile VID pins configuration.
to let the cpu run at it's normal speed you may have to lower the FSB to 133MHz (FSB266)
are you sure about the fsb? i suspect you have a Geode NX 1750, right? it has a multiplier of 10.5 and runs with an fsb of 133MHz at its designed speed of 1400MHz. please send the complete OPN and verify the speeds with CPUID.
maybe..but i don't think..
But where to get a Bios Version wich identify the Geode on the MB ?
I read about the 7GM5720.bin update file for the Bios (from the japanese Version).
Can anyone help - that would be great - thank you !
you don't have to believe me..but i say it again: the AMD Geode NX is nothing else than an Athlon XP Thouroughbred core with reduced voltage and speed.
to extend the OPN of your processor is no official AMD OPN. it is a relabled version of an AMD Athlon XP. did you ever search for the OPN on the net? what kind of hits did you get? isn't THAT strange?
..and why should I? If you like, do it yourself, they're sold at the moment on ebay.deCooperXS wrote:Please report all shops selling this particular Geode to AMD.
I did an found this: "The Geode NX 2001 exists certainly!" (AANXA2001FKC3G or ANXA2001FKC3D):cp wrote:... it is a relabled version of an AMD Athlon XP. did you ever search for the OPN on the net? what kind of hits did you get? isn't THAT strange?
http://fab51.com/mobile/tbred/geode_nx2001-e.html
- and last, not least for Helijet THIS might be his solution without any japanese BIOSHelijet wrote:...Is there any Bios-Update wich supports Geode CPU on my board ?
http://www.ocinside.de/go_d.html?/html/ ... mod_d.html
BTW, where did you buy this cpu, I would like to get myself one?
good luck
brin
thank GOOGLE
i know this site, too. take a look at the date of the site you found and then take a look at the date of this thread. and yes..i am aware that those Geode processors are sold via a large internet auction platform.I did an found this: "The Geode NX 2001 exists certainly!" (AANXA2001FKC3G or ANXA2001FKC3D):
the problem still is: the processors are sold as Geode NX1750..which they are certainly not. this causes some trouble among users as you can clearly see. i can understand that AMD wanted to sell a large amount of their old XP processors to an OEM vendor but i can not quite understand why AMD labeled them 'Geode'. obviously there is nothing geode-like on these processors, they are simply Athlon XP 2200+, nothing fancy, they even have the same core voltage. they _MAY_ have MP and/or MOBILE capabilities..but the latter will depend on the mainboard's bios capabilities or expert 3rd party software (like CrystalCPUID).
if you want to get a cool processor either buy a real Geode or get an old Athlon XP for cheap and modify its bridges for less voltage and MP/MOBILE. and don't buy those Geode NX 2001 processors as they are a pure ripoff.
