Dear friends all-over,
I have been looking for this info for some time now, tried Wim's various pages. The closest I got was DN0R (vs, DN0E) on a variety of ORLANDO MOBO's.
I need to know this for: Possible processors, max ram (EDO), Additional Vram modules (MOBO has 2 empty slots for these)
thank you
Yaakov Laks
Arad, Israel
Packard Bell-Amibios 1.00.03.DN0E Q: 1.upgrade? 2.Manual?
What system (make/model) did this board come from?
E as extra character is a yet unknown OEM:
http://www.elhvb.com/mboards/intel/
It is a variant of the NV430VX/Orlando, some info on the Packard Bell ones can be found here:
http://www.uktsupport.co.uk/pb/mb/680.htm
http://www.uktsupport.co.uk/pb/mb/682.htm
http://www.uktsupport.co.uk/pb/mb/683.htm
http://www.uktsupport.co.uk/pb/mb/685.htm
Please help us to complete the OEM table...
Dag Evasive | Edwin,
Bedankt voor de vlotte(?) (fast) antwoord.
Hoe is het in Breda, nog steeds wit met sneeuw?
And that is as much as I dare to risk my poor Dutch abilities (debilities?).
You asked: "What system (make/model) did this board come from?"
Reply: it is an ancient PB I'm trying to revive for a friend, a lable pasted to th front reads: Diplomat Multimedia Supreme
No documentation available, I ran Belarc advisor for any details I have.
Board is: Intel NV430VX - as you mentioned
Processor is P 166 (I tried & succeeded overclocking to 200).
I did look at all the various 68x you suggested, they all differ from the board I got - they do not have the Video connections at the back, there is blank space between the VGA and the USB connectors.
It had no HD, so I put one in, loaded it with win98SE, but it won't boot from HD, have to boot from floppy & then win98 operates OK.
Daag En weer bedankt
Yaakov Laks
Arad, Israel
Yaakov Laks
Arad, Israel
Aha. It is still white here and there but most of it has gone.
As for the windows problem:
Start from the bootdisk but do not start windows.
start fdisk
option 2, make a partition active
choose the partition where windows resides (most likey partition 1).
exit fdisk, take out floppy and reboot. That should do the trick.
As for the identification: so it is a Packard Bell, I mean it has got the Packard Bell logo on the case?
start fdisk
hi Edwin,
Too bad that skating on the frozen slooten is niet langer mogelijk...
Sure it is a PB - I wrote that in the subject line from the beginning...
My specific questions are:
1. Manual;
2. Max RAM possible on MOBO
3. Max processor speed (I assume 200, but YOUR logo says: Do not assume anything);
4. BIOS upgrade, if at all possible, and if yes then where can I find it and how to do it? (I tried AMI on the web, didn't find answer)
weer bedankt
Doooei of Dooey of gewoon Dag
Yaakov Laks
1. Manual;
weer bedankt
Yaakov Laks
