What motherboard and what type of graphics card do i need?
raydaffurn
I am looking to upgrade my graphics card but have no idea what type of motherboard i have and not sure what type of graphocs card i need to buy pci, pci express, agp etc.
I ran a program AIDA32 that gives me the following info:
Motherboard ID: 64-0528-000001-0010111-080808-bearlake$HPBEN000
Motherboard Name: Unknown
Bus Type: Intel GTL+
Bus width: 64 bit
Real Clock: 250mhz
Effective clock: 250mhz
Bandwith: 2000 MB/s
Any help would be appreciated.
OEM board from Asus, the IPIBL-LB which is called Benicia by HP.
http://h10025.www1.hp.com/ewfrf/wc/docu ... ct=3686671
http://h10025.www1.hp.com/ewfrf/wc/docu ... ct=3732620
Expansion slots
* One PCI
* One PCI Express x16 graphics (for graphics cards)
* Two PCI Express x1 (for cards such as network, sound, tv-tuner)
raydaffurn
OK so its pci express x16 for the graphics card, anyone know what the x16 is for, had a look at ebay and there is over 250 pci express cards but only a few list x16
There's more than 4000 of them listed on eBay:
http://desc.shop.ebay.com/items/Graphic ... Z15QQ_scZ1
Anyway, 16x is the maximum lanes per slot and I have not yet seen any PCIe graphics card with less or more. So that's not a problem.
What games are you planning on playing on your machine? What is your budget for the new card? What is the wattage listed on your power supply in that machine? Some cards need quite some power and not all power supplies can handle them.
raydaffurn
Its on a works pc, 2.0 dual core 1gb ram, 300gb hd its only to play soldier of fortune 3 or cod4 which my machine will support except the card. how do i check my power supply. as its only for the work was planning on getting a used on on ebay for about £20 as there will be 6 machines we need to get them for.
raydaffurn
also im in the UK
I. MINIMUM SYSTEM REQUIREMENTS
Minimum System Requirements
. Windows XP/Vista
. Pentium 4 2.5GHz
. 512 MB RAM
. DVD-ROM Drive
. 256MB DirectX 9.0c Compatible 3D accelerated video card with
. pixel/vertex shaders version 2.0 - ATI Radeon x800 or Nvidia GeForce 6800
. DirectX 9.0c (INCLUDED)
. Mouse and keyboard
. 3.3 GB uncompressed Hard Drive Space
. Sound Card - DirectX 9.0c Compatible
Recommended System Requirements
. Windows XP
. Core 2 Duo 2.0GHz
. 1 GB RAM
. DVD-ROM Drive
. 512MB DirectX 9.0c Compatible 3D accelerated video card with
. pixel/vertex shaders version - ATI Radeon x1900 or Nvidia GeForce 7900
6800:
http://desc.shop.ebay.com/items/_W0QQLH ... acat=27386
7900:
ATi cards will be about the same prices, as you can see you might reach the min spec for SOF3 with 20 quid. COD4 recommended requirements are equal to the SOF3 minimum requirements.
