The bios version was vba-2aa2.
The problem I had was that the Bios was not recognizing a new WD 40GB drive.
So, I went to SOYO site, downloaded AWDFlash.exe and the latest update for the bios VBA-2bab.bin
Created the Win98SE boot disk, and on another diskette placed the two files for flashing the Bios
Booted the computer, and when the flashing process started, in the second row I got write fail errors... And when I restarted the computer.. yes, you guessed right... ROM BIOS CHECKSUM ERROR...
Searching the web, I read about UNIFLASH, so I downloaded it, and ran it in the computer (It still let´s me boot with a diskette), but when UNIFLASH starts, it doesn´t recongnize the Flash Bios, so it doesn´t let me update it...
I see a message that asks me to make sure if the Bios is not write-protected, but I have searched in the manual, and I don´t see anywhere if it says that this mobo has such thing as a FLASH WRITE PROTECT jumper...
Can anyone give me a hint on what to do?
Would the only solution be a hot flashing using Uniflash?
JP
