#30911 by TheSwede
Sat Apr 09, 2005 10:53 pm
I have a laptop labeled "5600XT" but I can't find the brand!
Code: Select allProgram:   eSupport.com Chip Detect v0.80 2003.02.20
BIOS Date: 01/25/99
BIOS Type: PhoenixBIOS 4.0 Release 6.0      licensed to Intel
BIOS ID:   unknown
Superio:   NSC 332 rev 8 found at port 2Eh
Code: Select allStrukturtyp: BIOS
   Hersteller        : FIC
   Version           : NOTE BIOS Version /0000004L
   BIOS-Startsegment : EA40h
   Release-Datum     : 01/25/99
   BIOS-Laufzeitgr”áe: 87 KByte
   BIOS-ROM-Gr”áe    : 256 KByte
[...snip]
 Seriennummer       : FIC-0987654321abcdefghij
[...snip]
Strukturtyp: Tragbare Batterie
   Position          : Bottom of the system
   Hersteller        : FIC
   Herstelldatum     : 01/01/1980
   Seriennumer       : (leer)
   Ger„tename        : PC-VP-WP11
   Batterietyp       : unbekannt
   Kapazit„t         : unbekannt
   Spannung          : unbekannt
   SBDS Version      : (leer)
   Max Fehler in Bat.: 0%
   SBDS Seriennummer : 6F42 (hex)
   SBDS Herst.-Datum : 20.3.2038
   Chem. Bestandteile: (leer)
   Multiplikator     : 109
   BIOS-/OEM-spezif. : 20666F20h
Doesn't know if any of the above say anything about a model. I would expreciate if anyone could identify the modell and also maybe point me to the latest version. Current version (in use on my laptop) is 1.0H. I have a dump of the BIOS in a bios.bin-file if anyone wants to check it out!
The Swede
