hello
I need help with notebook asus L7200 in an upgrade of erroneous bios my pc doesn't make anything this dead
somebody can me you help I believe that the bios is a chip winbond w29c020, I can remove this chip and to record it
thank you
help notebook asus L7200 is dead
Did the flash complete? Was the power interrupted during the flashing?
If you can remove the PLCC chip and can reprogram it, then thats is whats going to have to happen. Do you have access to a raw .bin or .rom file from the manufacturer?
If you need help with file extraction, please post here.
Joe
Joe
