I was merrily doing some work on my laptop last night when my CPU cooling fan started making a strange noise, after about an hour my laptop simply conked out and would not come back on, I started it up this morning and it only fires up to, I think its the BIOS and asks me to press F2 I do so and it asks me all sorts of questions which I do not alter and try to exit and start as normal but it wont let me
Ok here is exactly what happens when I try to boot up:
I get a black screen with the following on it.
Pheonix cME First BIOS Notebook Pro
Via VLINK [PN800 + VT8235]
System BIOS - shadowed
Video BIOS - shadowed
Press F2 to enter set up.
(Then I go into main set up part)
MAIN:
System time: (Correct time shows)
System date: (Correct date shows)
Primary master: Installed CD/DVD
Secondary master: [None]
System memory: 640kb
Extended memory 456704kb
CPU type: Celeron(R) Processor
CPU speed: 1300mhz
BIOS Version: A.OB-0034-0812
ADVANCED:
Summary Screen: [Disabled]
Frame Buffer size: [64mb]
Legacy USB Support: [Enabled]
LAN Boot Control: [Disabled]
SECURITY:
Supervisor Password: Is Clear
User Password: Is Clear
Set Supervisor Password: [ENTER]
Set User Password: [ENTER]
Fixed Disk Boot Sector: [Normal]
Password on Boot: [Disabled]
BOOT:
Boot Device Priority:
1. USB FDC
2. IDE 2:
3. IDE 0:
4. USB HDD:
5. PCI LAN:
EXIT:
Exit Saving Changes
Exit Discarding Changes
Load Set Up Defaults
Discard Changes
Battery Refresh
And no matter what I do it goes back to the start to press F2
Can anyone shed some light please, as I have some very good music and stuff in my lappy??
Cheers in advance
Billy
