phoenix winphlash - flash on different os versions 32 to 64
i have a problem - i have a 64bit os and want to flash the new bios - but it works only on 32bit os. i found out and downloaded the 64bit version of winphlash. my idea was to save the bios file with a different computer (32bit os) and than use the 64bit winphlash to flash the saved bios file. i wasn't able to do so, and i am not sure why? is it possible or there is something that i miss\ don't know?
Better make a DOS bootdisk and use phlash16 then. If the manufacturer has not released a 64bit flasher/bios package it means they do not support this.
