HELLO.
PLEASE CAN YOU HELP ME MOD MY BIOS TO ENABLE AHCI
THANKS
HERE IS THE LINK TO ORIGINAL BIOS:
http://download7.msi.com/download_files ... 3d_309.zip
PLEASE help AHCI controller mod for MSI EX610
If you are running Vista you're out of luck. This laptop is using an ATi/AMD SB600 chip which has severe performance problems under Vista, no matter what drivers you use.
hmmm it's possible MSI choose to completely remove the option from the bios because this this was delivered with Vista, which made AHCI on this SB600 basically unusable in the first place. That would mean implementing a full SB600 module in the core which needs a full rewrite of the bios. There is a remote chance esupport has a commercial paid-for version but I'm pretty sure there's no free patch out there...
http://biosagentplus.com/?ref=822
