Hello,
new member for this forum,
well, i have a question to ask,recently i flashed my bios (pheonix) after flash, restarted pc - no display,no post,no beep, motherboard cpu fan power supply fan, motherboard powersupply led all working..can any of members here can help..guide me to recover?,before i flash bios, pc working perfectly.
motherboard - asus cuv4x-e 733mz /133.
thanks,
cappanie
problem after flash bios
Are you cleared the CMOS?
thanks for the reply, cmos has been cleared, let say if cmos cleared still display will appear....why no display?. the mistake i made is award bios, now similiar to pheonix..wrongly downloaded award flash.exe.i suppose to download pheonix!KURIAKI wrote:Are you cleared the CMOS?
please let me know what we can do ....
cappanie
Does the floppy light turn on at any time during the time you 1st turn it
on,, if so you could use the blind recovery method using the appropriate
commands in the autoexec.bat on a boot floppy.
If the floppy drive isn't active then pulling the chip & programming it is
what has to be done...
i noticed..no light on fdd while powering the the machine..about the programming chip.....i not very clear if can please guide.,and thank you for help this helpKenOath wrote:Does the floppy light turn on at any time during the time you 1st turn it
cappanie
Reprogramming the chip, meaning removing the bios chip from thecappanie wrote:i noticed..no light on fdd while powering the the machine..about the programming chip.....i not very clear if can please guide.,and thank you for help this helpKenOath wrote:Does the floppy light turn on at any time during the time you 1st turn it
cappanie
board & flashing the correct update to it with an eprom programmer...
If the chip is soldered on though then you'll have to pay someone to
unsolder it flash it & resolder it on, or socket the board to take the chip.
I'd be phoning a few of the local computer repair stores if I were you &
asking if they have, or know someone with an eprom programmer...
well,
i'm trying to flash,using hotflash method,with another mobo,chipset via694t,tried using aflash,error message,cant hook your bios!,later tried used awdflash,works,but cant find bin file.since i downloaded from asus ftp, the file similiar to 1003x.awd,so far i dont think so this is bin file. i need advise from members.why ext with awd? how to use it?
then,how to delete programs from bios chip (mine is syncmos),what imean is ,how to empty the contents of chip.
cappanie,
thanks for help
cappanie,
thanks for help
I often find when I get an error of either awdflash or amiflashcappanie wrote:well,
i later tried used awdflash,works,but cant find bin file.
cappanie,
thanks for help
not being able to find the bin file it's because the bin/rom file
is write protected.
Right click the bin file & make sure it isn't.
If it is , then take the tick out of the box that says "Read only"
